Hi all,
I'm relatively new to Cesium, so this might be a very basic question.
I'm trying to make a web viewer which shows 3D buildings. I have a database of more than 6 million buildings, which I serve to the browser using a WFS (geoserver).
At first, I used the Cesium-plugin of the guys from Oslandia (https://github.com/Oslandia/cesium-buildings) to get my buildings on the map. However, it was running quite slowly for my database.
I'm now looking into using entities. The code below shows what I'm trying to do. The problem that I have is that (of course) my buildings do not have the same amount of coordinates. That is why I make the for-loop to create the coor-variable (which looks like [X1, Y1, X2, Y2, .. X1, Y1].
However, when I try to put this variable in the polygon hierarchy, it only takes up the first three numbers of the coor-variable as X, Y, Z.
Any ideas what is going wrong?
If you have any other suggestions...
load(request, function(xhr) {
var geoJson = JSON.parse(xhr.responseText);
for (var f = 0; f < geoJson.features.length; f++) {
var building = geoJson.features[f];
var coor = ;
for (var i = 0; i < building.geometry.coordinates[0][0].length; i++) {
coor.push(building.geometry.coordinates[0][0][i][0]);
coor.push(building.geometry.coordinates[0][0][i][1]);
buildingList.push(viewer.entities.add({
polygon : {
hierarchy : Cesium.Cartesian3.fromArray(coor),
material : Cesium.Color.DARKORCHID.withAlpha(0.3),
outline : true,
outlineColor : Cesium.Color.BLACK,
extrudedHeight : building.geometry.coordinates[0][0][0][2]
Thanks!
Wout
