I’m trying to get more familiar with Cesium and I met an issue that I unfortunately cannot interpret. The code below is intended to test a simple example when one can track a groud projection of an air path of a plane. In fact, the code execution demonstrates that the plane path and the groud path are not synchronized as expected. The plane path lacks behind the ground path. In the end, the plane starts blinking and disappears from the screen. Could you please help me to understand what implementation of such scenarion by Cesium should demonstrate the correct behavior?
Oleg
scene3DOnly : true,
shadows : true,
timeline: false,
terrainShadows : Cesium.ShadowMode.ENABLED
var terrainProvider = new Cesium.CesiumTerrainProvider({
url : ‘https://assets.agi.com/stk-terrain/world’
viewer.terrainProvider = terrainProvider;
//---------------------- Start position of the plane ---------------------------
var startLongitude = 30, startLatitude = 20;
viewer.camera.flyTo({destination: Cesium.Cartesian3.fromDegrees(startLongitude, startLatitude, 900)});
//------------ Array of (time, position) samples along the plane route ---------
var airPathArray = ;
//------------ Array of the points of the ground path under the plane ----------
var groundPathArray = ;
//----------- Every 1 second a new point on the plane route is created ---------
var pathHandler = setInterval(function(){
var timeNow = new Cesium.JulianDate.now();
//timeNow = Cesium.JulianDate.addSeconds(timeNow, 2, new Cesium.JulianDate());
// At start it takes initial coordinates
if(airPathArray.length == 0){
airPathArray.push({time: timeNow, degrees: {longitude: startLongitude, latitude: startLatitude},
position: new Cesium.Cartesian3.fromDegrees(startLongitude, startLatitude, 600)});
groundPathArray.push(startLongitude);
groundPathArray.push(startLatitude);
// New next point coordinates are randomly taken
else{
var lon = airPathArray[airPathArray.length - 1].degrees.longitude + 0.0005 * (1 - Math.random());
var lat = airPathArray[airPathArray.length - 1].degrees.latitude + 0.0005 * (1 - Math.random());
airPathArray.push({time: timeNow, degrees: {longitude: lon, latitude: lat}, position: new Cesium.Cartesian3.fromDegrees(lon, lat, 600)});
groundPathArray.push(lon, lat);
// The maximum number of the route points is fixed
if(airPathArray.length > 15){
airPathArray.shift();
groundPathArray.shift();
// The updated route is ready for visualization
viewRoute();
}, 1000);
// Route visualization
function viewRoute() {
var trace = new Cesium.SampledPositionProperty();
for(var i = 0; i < airPathArray.length; i++)
trace.addSample(airPathArray[i].time, airPathArray[i].position);
plane.position = trace;
plane.position.setInterpolationOptions({
interpolationDegree : 1,
interpolationAlgorithm : Cesium.LinearApproximation
plane.orientation = new Cesium.VelocityOrientationProperty(trace);
goroundPath.corridor.positions = new Cesium.Cartesian3.fromDegreesArray(groundPathArray);
//--------------------------- CREATE A PLANE ENTITY ----------------------------
var plane = viewer.entities.add({
model : {
uri : ‘…/Apps/SampleData/models/CesiumAir/Cesium_Air.gltf’,
minimumPixelSize : 8,
color : Cesium.Color.WHITE
path : {
show : true,
leadTime : 0,
trailTime : 15,
width : 2,
resolution : 1,
material : new Cesium.PolylineGlowMaterialProperty({
glowPower : 0.25,
color : Cesium.Color.PALEGOLDENROD
//------------------------ CREATE A GROUND PATH ENTITY -------------------------
var goroundPath = viewer.entities.add({
corridor : {
width : 50.0,
material : Cesium.Color.BLUE.withAlpha(0.5)
