b28 GeoJSON display problems
Hi
Since the b28 update my GeoJSON vector graphics do not show up anymore. I checked through the changelog, but am really not sure what change has caused the errors. Could somebody please look at my code and point me in the right direction? I realize it is probably something very simple, but I am new to js and struggling to find the problem. Thanks in advance http://jsfiddle.net/ageojones/T6mck/
Andy
Extent was renamed to Rectangle. See https://github.com/AnalyticalGraphicsInc/cesium/blob/b28/CHANGES.md for the full list.
Change line 22 to:
var extent = new Cesium.Rectangle(west, south, east, north);
scene.camera.viewRectangle(extent, ellipsoid);
You may also prefer to use the more convenient Rectangle.fromDegrees function.
Thank you!
It seemed to start to load the points and then, I am getting some errors:
TypeError: undefined is not a function
    at updateObject
(http://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:60069:45)
    at DynamicBillboardVisualizer.update
(http://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:59905:13)
    at DataSourceDisplay.update
(http://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:81220:41)
    at http://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:131851:47
    at Event.raiseEvent
(http://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:21088:26)
    at Clock.tick
(http://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:23302:21)
    at CesiumWidget.render
(http://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:128127:39)
    at Viewer.render
(http://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:132
http://jsfiddle.net/ageojones/tdU2k/5/
Many, many thanks
Is it at all possible to use the old version of the API?
I am supposed to be showing this on monday and cannot make it work.
Thanks
I found b27 and am using a copy on my webserver. Thanks
DynamicBillboard properties must be instances of one of the Property types. Change line 33 to:
billboard.horizontalOrigin = new Cesium.ConstantProperty(Cesium.HorizontalOrigin.CENTER);
billboard.verticalOrigin = new Cesium.ConstantProperty(Cesium.VerticalOrigin.BOTTOM);
