I’m trying to load and remove czml extruded polygons at the event of camera moveEnd (eventListener) based on the position and altitude of the camera. But Im getting this error (image attached) variably and am not sure the exact cause. By what I understand the reason could be that widget.render() function is being called in Cesium.js but since visualizers are not defined rendering stops. Even if I hard-code and comment the catch() at line 161004 of Cesium Unminified to avoid popping of error panel, the rendering still stops. Following is some of my code to give you a little insight :
viewer.camera.moveEnd.addEventListener(function() {
camera_pos = viewer.camera.positionCartographic;
if (camera_pos.height <= 5000){
if(Cesium.Rectangle.contains(someRectangle,camera_pos)){
if(camera_pos.height > 2000){
if(!dataSource1._visualizers){
create_level_1(camera_pos.height);
if(dataSource1._visualizers && !Cesium.Rectangle.contains(ext_1,camera_pos)){
remove_level_1();
if(dataSource2._visualizers){
remove_level_2();
if(dataSource3._visualizers){
remove_level_3();
if(camera_pos.height <= 2000 && camera_pos.height > 1000){
if(!dataSource2._visualizers){
create_level_2(camera_pos.height);
remove_level_1();
if(dataSource2._visualizers && !Cesium.Rectangle.contains(ext_2,camera_pos)){
remove_level_2();
remove_level_3();
if(camera_pos.height <= 1000){
else if(dataSource1._visualizers && !Cesium.Rectangle.contains(ext_1,camera_pos)){
remove_level_1();
else if(dataSource2._visualizers && !Cesium.Rectangle.contains(ext_2,camera_pos)){
remove_level_2();
if(!dataSource3._visualizers){
create_level_3(camera_pos.height);
else if(dataSource3._visualizers && !Cesium.Rectangle.contains(ext_3,camera_pos)){
remove_level_3();
else if (camera_pos.height > 5000){
if(dataSource1._visualizers){
remove_level_1();
remove_level_2();
remove_level_3();
function create_level_1(ht){
var cam_pos = viewer.camera.positionCartographic;
var cam_lon = Cesium.Math.toDegrees(cam_pos.longitude);
var cam_lat = Cesium.Math.toDegrees(cam_pos.latitude);
ext_1 = Cesium.Rectangle.fromDegrees(cam_lon-0.008, cam_lat-0.008, cam_lon+0.008, cam_lat+0.008);
dataSource1.load(models); // ‘models’ is a string with CZML format
viewer.dataSources.add(dataSource1);
function create_level_2(ht){
ext_2 = Cesium.Rectangle.fromDegrees(cam_lon-0.002, cam_lat-0.002, cam_lon+0.002, cam_lat+0.002);
dataSource2.load(models);
viewer.dataSources.add(dataSource2);
function create_level_3(ht){
ext_3 = Cesium.Rectangle.fromDegrees(cam_lon-0.0015, cam_lat-0.0015, cam_lon+0.0015, cam_lat+0.0015);
dataSource3.load(models);
viewer.dataSources.add(dataSource3);
function remove_level_1(){
viewer.dataSources.remove(dataSource1);
dataSource1 = new Cesium.CzmlDataSource();
function remove_level_2(){
viewer.dataSources.remove(dataSource2);
dataSource2 = new Cesium.CzmlDataSource();
function remove_level_3(){
viewer.dataSources.remove(dataSource3);
dataSource3 = new Cesium.CzmlDataSource();
Help needed.
Parthesh.
