I am currently having a strange problem when adding an entity with a billboard/point. The point only renders if the baselayer changes. So only after a zoom/move which requires a switch of the image, the billboard/point is rendered. This problem only occurs when the sceneMode is set to columbus view, which is needed to display circles in a proper way.
As always I appreciate every input on this problem!
Thank you.
