Brightness Discrepancy in 2D Mode Across Different Regions
In 2D mode, the brightness varies across different regions. After loading the JSON data using the code from the sample at Cesium Sandcastle and switching to 2D mode, I noticed that the brightness in Africa is significantly higher than in other regions. I have also confirmed that this is not due to sunlight. I hope to receive assistance with this issue.
Hi @Feng_Zhou, welcome to the community!
We have a similar issue documented here:
There are a few possible workarounds in the discussion there.
See also this forum thread.
