If I call "scene.globe.getHeight" immediately after calling "scene.camera.flyTo", a drawing error occurs.
Code exsample:
https://jsfiddle.net/aminon/7kLg63bt/7/
An error occurs when you repeatedly left click on the view quickly and repeatedly.
When switching a list of locations, I want to switch the viewpoint to that location.
The user may manipulate this quickly and repeatedly.
Cesium 1.55
Chrome 73
Windows 10
No errors occurred in cesium 1.54 and 1.55(Unminified).
Error log is here:
RangeError: Invalid array length
at w (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:521:30793)
at T.createPotentiallyVisibleSet (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:522:1946)
at rt (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:522:25469)
at et (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:522:22852)
at pt (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:523:495)
at ft (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:523:682)
at Ie.render (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:523:12921)
at x.render (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:529:26396)
at t (https://cesiumjs.org/releases/1.55/Build/Cesium/Cesium.js:529:19846)
