If using the map in 2D and i set “trackedEntity” to a point, then any time i try using “camera.pickEllipsoid” it gives me points that are centered around lat, lon (0,0).
everything works as expected in 3D.
look at the following example. The first right click will place a point and set it to “trackedEntity”, from then on if you right click, it should add more points where you click, but they all end up around (0,0). zoom out to see so.
