Can someone help me pls!
i know maybe this issue has been solve in the past but im new working with cesium and i really need help. the thing is that working im sandcastle developing an app for viewing 3d noise maps in Bogotá, when i write my code in Sandcastle´s script it shows perfectly all that i´ve been dooing, but when i want to open the app directly in a browser it doesnt show anything only the 3D globe , i’ve been researching by my own and i have find out an example where it loads the necessary libraries for it to work, but simply nothing happens, how can i solve this problem, i would really appreciate any help.
The code that i use in the html part is the next one:
Mapas de Ruido @import url(../templates/bucket.css);
Cargando...
**3. Context. Why do you need to do this? We might know a better way to accomplish your goal.** like i said it is needed to visualize what i've done in sandcastle as a normal app. **4. The Cesium version you're using, your operating system and browser.** im using Cesium's 1.60v on Windows 10 and opening the app in Google Chrome.
Have you seen the getting started tutorial? It explains how to set up a CesiumJS app in a separate page:
https://cesium.com/docs/tutorials/getting-started/
You can also click “Open in new window” in Sandcastle to get a full-screen app that you could embed/iframe into your website. As long as you’re using your own Cesium ion token it should all work fine.
