Can't build for iOS with UE 5.5.4
I am having trouble building for iOS.
I am using:
Unreal Engine 5.5.4
Cesium for Unreal 2.16
macOS 15.5
Xcode 16.3
I create an empty project and add Cesium to it. macOS builds work fine but when I try to run it on my iPad, the following errors show up.
At first, I thought it was a general error but as soon as I remove Cesium from it, I can build again. Not to mention, I can also readily build the template projects to my iPad.
I will be also trying out earlier versions of Cesium to see if anything makes a difference. In the meantime, any kind of help is greatly appreciated.
Hi @MKI_Archi, welcome to the community!
Please see here:
I think that either disabling UBA or setting the MaxParallelActions to 2 (or both) may help in your case as well. It’s worth a try, at least.
Thank you so much for the response! Disabling UBA seemed to do the trick. Works great now.
