Can't hide point entities
If i create an entity with point graphics and change its “show” property to false it doesn’t hide, instead, it positions itself in the center of the screen while still being visible.
this issue only occurs when I’m in a Ubuntu environment
I’ve created an example to demonstrate my issue:
I need to be able to toggle entities visibility rather than destroying and recreating
Cesium version: 1.60
Operating system: Ubuntu 18.04.2 LTS
Browser: Google Chrome Version 76.0.3809.87 (Official Build) (64-bit)
Thanks for opening the bug report here: https://github.com/AnalyticalGraphicsInc/cesium/issues/8043
We do have a fix in mind, so hopefully it should be in the next release.
