Entity "show" property not working
I am trying to show/hide a rectangle graphics entity, but when I change it to true/false the entity shows up on the globe no matter what.
When the program first starts, I add a bunch of entities to viewer using viewer.entities.add(entity);
Then, I have attached a checkbox to show, or not show, the entity. I know that this works, because stepping through the firefox debugger does reveal that the "show" value for entity is actually being changed, but to no result on the globe.
for example,
entity.show = false;
(does not remove the entity from the globe)
I would like to toggle between showing and not showing the entity.
Cesium 1.7.1, Rel7, Firefox
Note that version 1.7.1 is about 3.5 years old at this point. Entity.show was added in 1.8, which is why it’s not working for you. Prior to that, show had to be set on each individual graphics object, for example, by setting entity.rectangle.show = false
Ok! Thanks
