I have added a polyline using:
viewer.entities.add(…)
How to I show and hide with a button by checking to see if entities are visible or not?
The following check does not work.
if(viewer.entities.values[0].polyline.show) {
viewer.entities.values[0].polyline.show = new Cesium.ConstantProperty(false);
} else {
viewer.entities.values[0].polyline.show = new Cesium.ConstantProperty(true);
The above does not work. I also tried…
if(viewer.entities.values[0].show) {
viewer.entities.values[0].show = new Cesium.ConstantProperty(false);
} else {
viewer.entities.values[0].show = new Cesium.ConstantProperty(true);
What is the right way?
I have done just
entity.show=false;
try
viewer.entities.values[0].show = false;
} else {
viewer.entities.values[0].show = true;
Sai, the reason your initial code does not work is because polyline.show is not a boolean but an object. You would need to do polyline.show.getValue(time) to retrieve the boolean value.
That being said, if you want to toggle an entire entity on/off, Brian has the right idea and entity.show is actually a simply boolean value (because it’s meant for just this type of UI use case).
If all you care about is toggling, a would change Brian’s code to
var entity = viewer.entities.values[0];
entity.show = !entity.show;
which avoid repeated lookups and avoid the need for if logic.
