When testing a RTC file with Cesium 1.50, I have noticed that the file would be displayed from the origin while having a RTC node. The bounding sphere of the object seems to be alright though
Same file/code with Cesium 1.49/48 displays the model where it should be
Hello world used with the attached file (I have noticed the file origin was the center of the earth increasing that scale factor)
Display Geo referenced gltf files, I am using RTC extension, if it’s not supported by Cesium 1.50, could you let me know a workaround (maybe using a transform node? can it be visualization artifacts?)
Version 1.50 , Ubuntu 16.04
Chrome Version 69.0.3497.100 (Official Build) (64-bit)
Thanks in advance,
-Lionel
model.gltf (6.11 KB)
. So then I guess all the extensions used should go to that list right? Then it would look like that if we would use KHR_techniques_webg right?
