For a git clone, you need the server to have access to the entire folder structure. This is also true for the release zips, i.e. if you are using Cesium-full-b29.zip, the entire contents of the zip file needs to be installed onto the server in order to use Sandcastle.
Related topics
Topic | Replies | Views | Activity | |
[cesium-dev] Cesium-1.32.zip contains Sandcastle with Cesium 1.31 ? | 0 | 165 | April 10, 2017 | |
How to use Cesium on own website ? | 4 | 210 | February 1, 2017 | |
Install on XAMPP | 1 | 261 | June 30, 2014 | |
Is it possible to create an offline version of cesium sandcastle? | 4 | 59 | August 29, 2024 | |
Ability to switch to different release versions for sandcastle? | 2 | 395 | January 20, 2017 |
