PS D:\Project\cesium-unreal\extern> cmake -B build-win -S . -G “Visual Studio 17 2022” -DUNREAL_ENGINE_ROOT=“D:\UnrealEngine\UE_5.2”
– Using Unreal Engine installation at: D:\UnrealEngine\UE_5.2
– VCPKG_TRIPLET x64-windows-unreal
– VCPKG_OVERLAY_PORTS D:/Project/cesium-unreal/extern/vcpkg-overlays
– VCPKG_OVERLAY_TRIPLETS D:/Project/cesium-unreal/extern/vcpkg-overlays/triplets
– EZVCPKG v0.1 starting up
Website: GitHub - jherico/ezvcpkg
– EZVCPKG_BASEDIR envrionment variable not found and basedir not set, using default /.ezvcpkg
– EZVCPKG initializing
commit: 2024.11.16
repository: git@github.com:microsoft/vcpkg.git
local dir: /.ezvcpkg/2024.11.16
– EZVCPKG Building/Verifying package asyncplusplus using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package expected-lite using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package fmt using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package glm using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package rapidjson using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package spdlog using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package stb using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package uriparser using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package abseil using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package draco using triplet x64-windows-unreal
– EZVCPKG Building/Verifying package ktx using triplet x64-windows-unreal
CMake Error at cesium-native/cmake/ezvcpkg/ezvcpkg.cmake:83 (message):
EZVCPKG failed with error 1
Call Stack (most recent call first):
cesium-native/cmake/ezvcpkg/ezvcpkg.cmake:184 (EZVCPKG_CHECK_RESULTS)
cesium-native/cmake/ezvcpkg/ezvcpkg.cmake:276 (EZVCPKG_BUILD)
cesium-native/cmake/ezvcpkg/ezvcpkg.cmake:290 (EZVCPKG_FETCH_IMPL)
cesium-native/CMakeLists.txt:66 (ezvcpkg_fetch)
*** The output from the command was:
Computing installation plan…
The following packages will be built and installed:
ktx:x64-windows-unreal@4.3.0-beta1#1 – D:/Project/cesium-unreal/extern/vcpkg-overlays\ktx
Detecting compiler hash for triplet x64-windows-unreal…
– Automatically setting %HTTP(S)_PROXY% environment variables to “127.0.0.1:10794”.
Compiler found: D:/VisualStudio/VS2022/Community/VC/Tools/MSVC/14.42.34433/bin/Hostx64/x64/cl.exe
Restored 0 package(s) from C:\Users\jingyubo\AppData\Local\vcpkg\archives in 107 us. Use --debug to see more details.
Installing 1/1 ktx:x64-windows-unreal@4.3.0-beta1#1…
Building ktx:x64-windows-unreal@4.3.0-beta1#1…
D:\Project\cesium-unreal\extern\vcpkg-overlays\triplets\x64-windows-unreal.cmake: info: loaded overlay triplet from here
D:/Project/cesium-unreal/extern/vcpkg-overlays\ktx: info: installing overlay port from here
– Using cached KhronosGroup-KTX-Software-v4.3.0-beta1.tar.gz.
– Cleaning sources at D:/.ezvcpkg/2024.11.16/buildtrees/ktx/src/.3.0-beta1-4964dfdc8e.clean. Use --editable to skip cleaning for the packages you specify.
– Extracting source D:/.ezvcpkg/2024.11.16/downloads/KhronosGroup-KTX-Software-v4.3.0-beta1.tar.gz
– Applying patch 0001-Use-vcpkg-zstd.patch
– Applying patch 0002-Fix-versioning.patch
– Applying patch 0003-mkversion.patch
– Applying patch 0004-quirks.patch
– Applying patch 0005-no-vendored-libs.patch
– Applying patch CESIUM-0001-do-not-define-_DEBUG.patch
– Applying patch CESIUM-0002-not-a-framework.patch
– Applying patch CESIUM-0003-ios-normal-header-path.patch
– Using source at D:/.ezvcpkg/2024.11.16/buildtrees/ktx/src/.3.0-beta1-4964dfdc8e.clean
– Found external ninja(‘1.12.1’).
– Configuring x64-windows-unreal-dbg
CMake Error at scripts/cmake/vcpkg_execute_required_process.cmake:127 (message):
Command failed: D:/.ezvcpkg/2024.11.16/downloads/tools/cmake-3.30.1-windows/cmake-3.30.1-windows-i386/bin/cmake.exe D:/.ezvcpkg/2024.11.16/buildtrees/ktx/src/.3.0-beta1-4964dfdc8e.clean -G Ninja -DCMAKE_BUILD_TYPE=Debug -DCMAKE_INSTALL_PREFIX=D:/.ezvcpkg/2024.11.16/packages/ktx_x64-windows-unreal/debug -DFETCHCONTENT_FULLY_DISCONNECTED=ON -DKTX_VERSION_FULL=v4.3.0-beta1 -DKTX_FEATURE_TESTS=OFF -DKTX_FEATURE_LOADTEST_APPS=OFF -DKTX_FEATURE_STATIC_LIBRARY=1 -DKTX_FEATURE_TOOLS=OFF -DKTX_FEATURE_VK_UPLOAD=OFF -DCMAKE_DISABLE_FIND_PACKAGE_Vulkan=1 -DCMAKE_MAKE_PROGRAM=D:/VisualStudio/VS2022/Community/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/ninja.exe -DBUILD_SHARED_LIBS=OFF -DVCPKG_CHAINLOAD_TOOLCHAIN_FILE=D:/.ezvcpkg/2024.11.16/scripts/toolchains/windows.cmake -DVCPKG_TARGET_TRIPLET=x64-windows-unreal -DVCPKG_SET_CHARSET_FLAG=ON -DVCPKG_PLATFORM_TOOLSET=v143 -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DCMAKE_FIND_PACKAGE_NO_PACKAGE_REGISTRY=ON -DCMAKE_FIND_PACKAGE_NO_SYSTEM_PACKAGE_REGISTRY=ON -DCMAKE_INSTALL_SYSTEM_RUNTIME_LIBS_SKIP=TRUE -DCMAKE_VERBOSE_MAKEFILE=ON -DVCPKG_APPLOCAL_DEPS=OFF -DCMAKE_TOOLCHAIN_FILE=D:/.ezvcpkg/2024.11.16/scripts/buildsystems/vcpkg.cmake -DCMAKE_ERROR_ON_ABSOLUTE_INSTALL_DESTINATION=ON -DVCPKG_CXX_FLAGS=/Zp8 -DVCPKG_CXX_FLAGS_RELEASE= -DVCPKG_CXX_FLAGS_DEBUG= -DVCPKG_C_FLAGS=/Zp8 -DVCPKG_C_FLAGS_RELEASE= -DVCPKG_C_FLAGS_DEBUG= -DVCPKG_CRT_LINKAGE=dynamic -DVCPKG_LINKER_FLAGS= -DVCPKG_LINKER_FLAGS_RELEASE= -DVCPKG_LINKER_FLAGS_DEBUG= -DVCPKG_TARGET_ARCHITECTURE=x64 -DCMAKE_INSTALL_LIBDIR:STRING=lib -DCMAKE_INSTALL_BINDIR:STRING=bin -D_VCPKG_ROOT_DIR=D:/.ezvcpkg/2024.11.16 -D_VCPKG_INSTALLED_DIR=D:/.ezvcpkg/2024.11.16/installed -DVCPKG_MANIFEST_INSTALL=OFF -DCMAKE_MSVC_RUNTIME_LIBRARY:STRING=MultiThreadedDLL “-DCMAKE_CXX_FLAGS_DEBUG:STRING=/MD /Z7 /Ob0 /Od /RTC1” “-DCMAKE_C_FLAGS_DEBUG:STRING=/MD /Z7 /Ob0 /Od /RTC1”
Working Directory: D:/.ezvcpkg/2024.11.16/buildtrees/ktx/x64-windows-unreal-dbg
Error code: 1
See logs for more information:
D:.ezvcpkg\2024.11.16\buildtrees\ktx\config-x64-windows-unreal-dbg-CMakeCache.txt.log
D:.ezvcpkg\2024.11.16\buildtrees\ktx\config-x64-windows-unreal-dbg-out.log
D:.ezvcpkg\2024.11.16\buildtrees\ktx\config-x64-windows-unreal-dbg-err.log
installed/x64-windows/share/vcpkg-cmake/vcpkg_cmake_configure.cmake:287 (vcpkg_execute_required_process)
D:/Project/cesium-unreal/extern/vcpkg-overlays/ktx/portfile.cmake:44 (vcpkg_cmake_configure)
scripts/ports.cmake:196 (include)
error: building ktx:x64-windows-unreal failed with: BUILD_FAILED
See Troubleshoot build failures | Microsoft Learn for more information.
Elapsed time to handle ktx:x64-windows-unreal: 7.8 s
Please ensure you’re using the latest port files with git pull and vcpkg update.
Then check for known issues at:
GitHub · Where software is built
You can submit a new issue at:
Sign in to GitHub · GitHub
