I package cesium for unreal plugin,and assigned to the cesium-unreal directory
ue4 has a lot of errors
UATHelper: Package Plugin Task (Windows): Stacktrace: 在 System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
UATHelper: Package Plugin Task (Windows): 在 System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
UATHelper: Package Plugin Task (Windows): 在 AutomationTool.InternalUtils.SafeCopyFile(String SourceName, String TargetName, Boolean bQuiet, List1 IniKeyBlacklist, List1 IniSectionBlacklist) 位置 D:\Build++UE4\Sync\Engine\Source\Programs\AutomationTool\AutomationUtils\Utils.cs:行号 378
UATHelper: Package Plugin Task (Windows): ERROR: Failed to copy E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_enc.dir\Release\draco_co.6CDF4B51.tlog\draco_compression_attributes_pred_schemes_enc.lastbuildstate to E:\UEProjects\cesium-unreal-samples\Plugins\cesium-un
real\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_enc.dir\Release\draco_co.6CDF4B51.tlog\draco_compression_attributes_pred_schemes_enc.lastbuildstate
UATHelper: Package Plugin Task (Windows): SafeCopyFile Exception was Exception in mscorlib: 未能找到路径“E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_enc.dir\Debug\draco_co.6CDF4B51.tlog\draco_compression_attributes_pre
d_schemes_enc.lastbuildstate”的一部分。
UATHelper: Package Plugin Task (Windows): ERROR: Failed to copy E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_enc.dir\Debug\draco_co.6CDF4B51.tlog\draco_compression_attributes_pred_schemes_enc.lastbuildstate to E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unre
al\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_enc.dir\Debug\draco_co.6CDF4B51.tlog\draco_compression_attributes_pred_schemes_enc.lastbuildstate
UATHelper: Package Plugin Task (Windows): SafeCopyFile Exception was Exception in mscorlib: 未能找到路径“E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_dec.dir\Release\draco_co.9EA33BAC.tlog\draco_compression_attributes_p
red_schemes_dec.lastbuildstate”的一部分。
UATHelper: Package Plugin Task (Windows): ERROR: Failed to copy E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_dec.dir\Release\draco_co.9EA33BAC.tlog\draco_compression_attributes_pred_schemes_dec.lastbuildstate to E:\UEProjects\cesium-unreal-samples\Plugins\cesium-un
real\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_dec.dir\Release\draco_co.9EA33BAC.tlog\draco_compression_attributes_pred_schemes_dec.lastbuildstate
UATHelper: Package Plugin Task (Windows): SafeCopyFile Exception was Exception in mscorlib: 未能找到路径“E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_dec.dir\Debug\draco_co.9EA33BAC.tlog\draco_compression_attributes_pre
UATHelper: Package Plugin Task (Windows): ERROR: Failed to copy E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_dec.dir\Debug\draco_co.9EA33BAC.tlog\draco_compression_attributes_pred_schemes_dec.lastbuildstate to E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unre
al\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_pred_schemes_dec.dir\Debug\draco_co.9EA33BAC.tlog\draco_compression_attributes_pred_schemes_dec.lastbuildstate
UATHelper: Package Plugin Task (Windows): SafeCopyFile Exception was Exception in mscorlib: 未能找到路径“E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_dec.dir\Debug\draco_co.C8B46396.tlog\draco_compression_attributes_dec.lastbuildsta
te”的一部分。
UATHelper: Package Plugin Task (Windows): ERROR: Failed to copy E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_dec.dir\Debug\draco_co.C8B46396.tlog\draco_compression_attributes_dec.lastbuildstate to E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostPro
ject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_dec.dir\Debug\draco_co.C8B46396.tlog\draco_compression_attributes_dec.lastbuildstate
UATHelper: Package Plugin Task (Windows): SafeCopyFile Exception was Exception in mscorlib: 未能找到路径“E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_enc.dir\Debug\draco_co.96AA2BF4.tlog\draco_compression_attributes_enc.lastbuildsta
te”的一部分。
UATHelper: Package Plugin Task (Windows): ERROR: Failed to copy E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_enc.dir\Debug\draco_co.96AA2BF4.tlog\draco_compression_attributes_enc.lastbuildstate to E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostPro
ject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_enc.dir\Debug\draco_co.96AA2BF4.tlog\draco_compression_attributes_enc.lastbuildstate
UATHelper: Package Plugin Task (Windows): SafeCopyFile Exception was Exception in mscorlib: 未能找到路径“E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_enc.dir\Release\draco_co.96AA2BF4.tlog\draco_compression_attributes_enc.lastbuilds
tate”的一部分。
UATHelper: Package Plugin Task (Windows): ERROR: Failed to copy E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_enc.dir\Release\draco_co.96AA2BF4.tlog\draco_compression_attributes_enc.lastbuildstate to E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostP
roject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_enc.dir\Release\draco_co.96AA2BF4.tlog\draco_compression_attributes_enc.lastbuildstate
UATHelper: Package Plugin Task (Windows): SafeCopyFile Exception was Exception in mscorlib: 未能找到路径“E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostProject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_dec.dir\Release\draco_co.C8B46396.tlog\draco_compression_attributes_dec.lastbuilds
tate”的一部分。
UATHelper: Package Plugin Task (Windows): ERROR: Failed to copy E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_dec.dir\Release\draco_co.C8B46396.tlog\draco_compression_attributes_dec.lastbuildstate to E:\UEProjects\cesium-unreal-samples\Plugins\cesium-unreal\CesiumForUnreal\HostP
roject\Plugins\CesiumForUnreal\extern\build\cesium-native\extern\draco\draco_compression_attributes_dec.dir\Release\draco_co.C8B46396.tlog\draco_compression_attributes_dec.lastbuildstate
