Cesium for Unreal is currently broken on Epic Fab - FIXED!
Hi everyone,
We published a new version of Cesium for Unreal yesterday, but it seems something has gone wrong in Epic’s process to make it available on Fab and via the Epic Launcher. As a result, if you install or upgrade from those sources right now, you’ll get a broken version of the plugin. The first and most obvious symptom will be messages like this in the Output Log:
LogHttp: Warning: Reached threaded request limit (11)
We’re working with Epic to get this fixed, but in the meantime, hold off on upgrading the plugin. If you want to use v2.16.0 right away, you can install it from our GitHub Releases page by following these instructions:
I’ll post again here when Epic have fixed this problem. Sorry for the inconvenience!
This has been fixed! It is safe to install or upgrade Cesium for Unreal from the Epic Launcher / Fab now.
