Hello –
I have a world that I’ve been using with Unreal Engine 4.26.2 and Cesium 1.6.2. I wanted to upgrade to Cesium 1.11.0 to take advantage of some of the new features. The cesium plugin was originally installed via the marketplace on the epic games launcher and I updated to v1.11.0 through the same method. However, I am now unable to successfully open my world through the Unreal Engine. I am receiving a message that says “Plugin ‘CesiumForUnreal’ failed to load because module ‘CesiumRuntime’ could not be loaded. There may be an operating system error or the module may not be properly set up.”
This error occurs regardless of if I am using a brand-new world or the world I was previously working in and also occurs when attempting to upgrade to Cesium 1.11.0 on a different computer. I was able to get a brand-new world to work in Unreal Engine 4.27 with the latest Cesium plug-in so this seems to be an issue exclusive to 4.26. Ultimately, I would prefer to fix 4.26 and not use have to use 4.27. As additional information I am running OSX version 10.15.7.
Do you know how to solve this?
Thanks!
