In the cesiumJS code I use, while integrating the 3d geojson format files into the map, I want to integrate it by specifying the file location directly from my computer for example(Desktop\geojson\test.geojson), not using the token and file id from the cesium.ion database.
I don’t have any problems when I write using cesium ion, it works but as i said i want to import from local . Let me share with you the function of the code I am using now;
async function addBuildingGeoJSON1() {
const geoJSONURL = await Cesium.IonResource.fromAssetId(1182187);
const geoJSON = await Cesium.GeoJsonDataSource.load(geoJSONURL, {
clampToGround: true,
const dataSource = await viewer.dataSources.add(geoJSON);
for (const entity of dataSource.entities.values) {
entity.polygon.classificationType = Cesium.ClassificationType.TERRAIN;
Hi @Egemen_Ozgur,
for local files you have to use a html-input-element with type=“file” and some temporary created URL for that file. You can have a look at following code, I have quickly copied from my app. Maybe you can use it and make it work for you:
// adding eventListener to html-input-Element with type="file"
document.getElementById('localfiles').addEventListener('change', loadFiles, false);
// function for loading local geojson
function loadFiles (event) {
let files = event.target.files;
// for-loop cause I want to support multiple files at once
for (i = 0; i < files.length; i++) {
let tmppath = URL.createObjectURL(event.target.files[i]);
Cesium.GeoJsonDataSource.clampToGround = true;
let geojson = new Cesium.GeoJsonDataSource();
let data = geojson.load(tmppath);
data.then(function(geojson) {
viewer.dataSources.add(geojson);
let entities = geojson.entities.values;
let colorHash = {};
for (k = 0; k < entities.length; k++) {
let entity = entities[k];
let id = entity.id;
if (entity.polygon) {
let color = colorHash[id];
if (!color) {
color = Cesium.Color.fromRandom({alpha: 1});
colorHash[id] = color;
entity.polygon.material = color;
entity.polygon.outline = false;
} else if (entity.polyline) {
entity.polyline.material = Cesium.Color.fromRandom();
entity.polyline.width = 3;
entity.polyline.classificationType = Cesium.ClassificationType.TERRAIN;
} else {
viewer.zoomTo(geojson);
}).otherwise(function(error){
window.alert(error);
There is some code for random colors there, which you maybe dont need.
Best, Lennart
