Sure, I can share that, it’s kind of long though! Unfortunately it’s actually too long to post entirely, so I’ll post what looks like the relevant part. Actually though, this was trying to launch it through 2021.3.6
/additionalfile:"Library/Bee/artifacts/2400b0aE.dag/CesiumRuntime.AdditionalFile.txt"
##### Custom Environment Variables
DOTNET_MULTILEVEL_LOOKUP=0
##### ExitCode
1
##### Output
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/Cesium3DTileset.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumBingMapsRasterOverlay.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumCreditSystem.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGeoreference.cs(3,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGlobeAnchor.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumIonRasterOverlay.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumMetadata.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTileMapServiceRasterOverlay.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTransforms.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumWebMapServiceRasterOverlay.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(2,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/NativeDownloadHandler.cs(1,7): error CS0246: The type or namespace name 'Reinterop' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumBingMapsRasterOverlay.cs(27,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumBingMapsRasterOverlay.cs(27,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumMetadata.cs(9,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumMetadata.cs(9,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumCreditSystem.cs(20,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumCreditSystem.cs(20,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumIonRasterOverlay.cs(9,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumIonRasterOverlay.cs(9,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGlobeAnchor.cs(78,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGlobeAnchor.cs(78,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGeoreference.cs(62,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGeoreference.cs(62,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/Cesium3DTileset.cs(41,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/Cesium3DTileset.cs(41,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumMetadata.cs(12,31): error CS8795: Partial method 'CesiumMetadata.loadMetadata(Transform, int, MetadataProperty[])' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumMetadata.cs(14,29): error CS8795: Partial method 'CesiumMetadata.getNumberOfProperties(Transform)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTransforms.cs(9,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTransforms.cs(9,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumWebMapServiceRasterOverlay.cs(10,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumWebMapServiceRasterOverlay.cs(10,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTransforms.cs(20,13): error CS8795: Partial method 'CesiumTransforms.LongitudeLatitudeHeightToEarthCenteredEarthFixed(double3)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTransforms.cs(31,13): error CS8795: Partial method 'CesiumTransforms.EarthCenteredEarthFixedToLongitudeLatitudeHeight(double3)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTileMapServiceRasterOverlay.cs(10,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTileMapServiceRasterOverlay.cs(10,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(30,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(30,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(37,31): error CS8795: Partial method 'MetadataProperty.GetPropertyName()' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(42,29): error CS8795: Partial method 'MetadataProperty.IsNormalized()' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(48,28): error CS8795: Partial method 'MetadataProperty.GetComponentCount()' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(50,31): error CS8795: Partial method 'MetadataProperty.GetComponent(MetadataProperty, int)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(55,37): error CS8795: Partial method 'MetadataProperty.GetComponentType()' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(60,37): error CS8795: Partial method 'MetadataProperty.GetMetadataType()' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(67,30): error CS8795: Partial method 'MetadataProperty.GetInt8(sbyte)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(74,29): error CS8795: Partial method 'MetadataProperty.GetUInt8(byte)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(81,30): error CS8795: Partial method 'MetadataProperty.GetInt16(short)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(88,31): error CS8795: Partial method 'MetadataProperty.GetUInt16(ushort)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(95,30): error CS8795: Partial method 'MetadataProperty.GetInt32(int)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(102,31): error CS8795: Partial method 'MetadataProperty.GetUInt32(uint)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(109,30): error CS8795: Partial method 'MetadataProperty.GetInt64(long)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(116,31): error CS8795: Partial method 'MetadataProperty.GetUInt64(ulong)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(123,30): error CS8795: Partial method 'MetadataProperty.GetFloat32(float)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(130,31): error CS8795: Partial method 'MetadataProperty.GetFloat64(double)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(137,32): error CS8795: Partial method 'MetadataProperty.GetBoolean(bool)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/MetadataProperty.cs(144,31): error CS8795: Partial method 'MetadataProperty.GetString(string)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/NativeDownloadHandler.cs(7,6): error CS0246: The type or namespace name 'ReinteropNativeImplementationAttribute' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/NativeDownloadHandler.cs(7,6): error CS0246: The type or namespace name 'ReinteropNativeImplementation' could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/NativeDownloadHandler.cs(27,30): error CS8795: Partial method 'NativeDownloadHandler.ReceiveDataNative(IntPtr, int)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumIonRasterOverlay.cs(44,41): error CS8795: Partial method 'CesiumIonRasterOverlay.AddToTileset(Cesium3DTileset)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumIonRasterOverlay.cs(45,41): error CS8795: Partial method 'CesiumIonRasterOverlay.RemoveFromTileset(Cesium3DTileset)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumBingMapsRasterOverlay.cs(65,41): error CS8795: Partial method 'CesiumBingMapsRasterOverlay.AddToTileset(Cesium3DTileset)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumBingMapsRasterOverlay.cs(68,41): error CS8795: Partial method 'CesiumBingMapsRasterOverlay.RemoveFromTileset(Cesium3DTileset)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGlobeAnchor.cs(617,37): error CS8795: Partial method 'CesiumGlobeAnchor.AdjustOrientation(CesiumGlobeAnchor, double3, double3)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTileMapServiceRasterOverlay.cs(86,41): error CS8795: Partial method 'CesiumTileMapServiceRasterOverlay.AddToTileset(Cesium3DTileset)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumTileMapServiceRasterOverlay.cs(87,41): error CS8795: Partial method 'CesiumTileMapServiceRasterOverlay.RemoveFromTileset(Cesium3DTileset)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumWebMapServiceRasterOverlay.cs(122,41): error CS8795: Partial method 'CesiumWebMapServiceRasterOverlay.AddToTileset(Cesium3DTileset)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumWebMapServiceRasterOverlay.cs(123,41): error CS8795: Partial method 'CesiumWebMapServiceRasterOverlay.RemoveFromTileset(Cesium3DTileset)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGeoreference.cs(263,30): error CS8795: Partial method 'CesiumGeoreference.InitializeOrigin()' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGeoreference.cs(269,30): error CS8795: Partial method 'CesiumGeoreference.RecalculateOrigin()' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGeoreference.cs(311,13): error CS8795: Partial method 'CesiumGeoreference.TransformUnityPositionToEarthCenteredEarthFixed(double3)' must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@0.1.1/Runtime/CesiumGeoreference.cs(322,13): error CS8795: Partial method
