Ubuntu 20.04 installation issue
I followed the steps in the Quickstart tutorial, but after installing Cesium for Unity through the package manager, I get the following errors in console, which surely doesn’t bode well. No “Cesium” ever shows up in the menu at the top. This is with the latest Unity version 2022.3.6f1. Is there a known solution to this?
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTile.cs(2,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumBingMapsRasterOverlay.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumCreditSystem.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumDebugColorizeTilesRasterOverlay.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGeoreference.cs(3,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGlobeAnchor.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumIonRasterOverlay.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumMetadata.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileExcluder.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileMapServiceRasterOverlay.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWebMapServiceRasterOverlay.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWgs84Ellipsoid.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/NativeDownloadHandler.cs(1,7): error CS0246: The type or namespace name ‘Reinterop’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTile.cs(13,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTile.cs(13,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTile.cs(34,39): error CS8795: Partial method ‘Cesium3DTile.getBounds(IntPtr, double4x4)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(31,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(31,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(55,30): error CS8795: Partial method ‘CesiumFeature.GetInt8(string, sbyte)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(63,29): error CS8795: Partial method ‘CesiumFeature.GetUInt8(string, byte)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(71,30): error CS8795: Partial method ‘CesiumFeature.GetInt16(string, short)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(79,31): error CS8795: Partial method ‘CesiumFeature.GetUInt16(string, ushort)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(87,30): error CS8795: Partial method ‘CesiumFeature.GetInt32(string, int)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(95,31): error CS8795: Partial method ‘CesiumFeature.GetUInt32(string, uint)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(103,30): error CS8795: Partial method ‘CesiumFeature.GetInt64(string, long)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(111,31): error CS8795: Partial method ‘CesiumFeature.GetUInt64(string, ulong)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(119,30): error CS8795: Partial method ‘CesiumFeature.GetFloat32(string, float)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(127,31): error CS8795: Partial method ‘CesiumFeature.GetFloat64(string, double)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(135,32): error CS8795: Partial method ‘CesiumFeature.GetBoolean(string, bool)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(143,31): error CS8795: Partial method ‘CesiumFeature.GetString(string, string)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(152,30): error CS8795: Partial method ‘CesiumFeature.GetComponentInt8(string, int, sbyte)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(161,29): error CS8795: Partial method ‘CesiumFeature.GetComponentUInt8(string, int, byte)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(170,30): error CS8795: Partial method ‘CesiumFeature.GetComponentInt16(string, int, short)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(179,31): error CS8795: Partial method ‘CesiumFeature.GetComponentUInt16(string, int, ushort)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(188,30): error CS8795: Partial method ‘CesiumFeature.GetComponentInt32(string, int, int)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(197,31): error CS8795: Partial method ‘CesiumFeature.GetComponentUInt32(string, int, uint)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(206,30): error CS8795: Partial method ‘CesiumFeature.GetComponentInt64(string, int, long)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(215,31): error CS8795: Partial method ‘CesiumFeature.GetComponentUInt64(string, int, ulong)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(224,30): error CS8795: Partial method ‘CesiumFeature.GetComponentFloat32(string, int, float)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(234,31): error CS8795: Partial method ‘CesiumFeature.GetComponentFloat64(string, int, double)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(243,32): error CS8795: Partial method ‘CesiumFeature.GetComponentBoolean(string, int, bool)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(252,31): error CS8795: Partial method ‘CesiumFeature.GetComponentString(string, int, string)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(258,28): error CS8795: Partial method ‘CesiumFeature.GetComponentCount(string)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(264,37): error CS8795: Partial method ‘CesiumFeature.GetComponentType(string)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(270,37): error CS8795: Partial method ‘CesiumFeature.GetMetadataType(string)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumFeature.cs(276,29): error CS8795: Partial method ‘CesiumFeature.IsNormalized(string)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(41,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(41,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGeoreference.cs(62,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGeoreference.cs(62,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumCreditSystem.cs(93,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumCreditSystem.cs(93,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGlobeAnchor.cs(607,30): error CS8795: Partial method ‘CesiumGlobeAnchor.SetNewLocalToGlobeFixedMatrix(double4x4)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGlobeAnchor.cs(615,30): error CS8795: Partial method ‘CesiumGlobeAnchor.SetNewLocalToGlobeFixedMatrixFromTransform()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGlobeAnchor.cs(623,36): error CS8795: Partial method ‘CesiumGlobeAnchor.GetLocalToEastUpNorthRotation()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGlobeAnchor.cs(631,30): error CS8795: Partial method ‘CesiumGlobeAnchor.SetLocalToEastUpNorthRotation(quaternion)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(653,30): error CS8795: Partial method ‘Cesium3DTileset.SetShowCreditsOnScreen(bool)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(655,30): error CS8795: Partial method ‘Cesium3DTileset.Start()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(656,30): error CS8795: Partial method ‘Cesium3DTileset.Update()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(657,30): error CS8795: Partial method ‘Cesium3DTileset.OnValidate()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(659,30): error CS8795: Partial method ‘Cesium3DTileset.OnEnable()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(660,30): error CS8795: Partial method ‘Cesium3DTileset.OnDisable()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(666,29): error CS8795: Partial method ‘Cesium3DTileset.RecreateTileset()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/Cesium3DTileset.cs(671,29): error CS8795: Partial method ‘Cesium3DTileset.FocusTileset()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGeoreference.cs(500,35): error CS8795: Partial method ‘CesiumGeoreference.ComputeLocalToEarthCenteredEarthFixedTransformation()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumBingMapsRasterOverlay.cs(27,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumBingMapsRasterOverlay.cs(27,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumCreditSystem.cs(178,30): error CS8795: Partial method ‘CesiumCreditSystem.UpdateCredits(bool)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumBingMapsRasterOverlay.cs(67,41): error CS8795: Partial method ‘CesiumBingMapsRasterOverlay.AddToTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumBingMapsRasterOverlay.cs(70,41): error CS8795: Partial method ‘CesiumBingMapsRasterOverlay.RemoveFromTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileMapServiceRasterOverlay.cs(10,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileMapServiceRasterOverlay.cs(10,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileMapServiceRasterOverlay.cs(89,41): error CS8795: Partial method ‘CesiumTileMapServiceRasterOverlay.AddToTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileMapServiceRasterOverlay.cs(91,41): error CS8795: Partial method ‘CesiumTileMapServiceRasterOverlay.RemoveFromTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumIonRasterOverlay.cs(9,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumIonRasterOverlay.cs(9,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumIonRasterOverlay.cs(47,41): error CS8795: Partial method ‘CesiumIonRasterOverlay.AddToTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumIonRasterOverlay.cs(49,41): error CS8795: Partial method ‘CesiumIonRasterOverlay.RemoveFromTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/NativeDownloadHandler.cs(7,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/NativeDownloadHandler.cs(7,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/NativeDownloadHandler.cs(27,30): error CS8795: Partial method ‘NativeDownloadHandler.ReceiveDataNative(IntPtr, int)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileExcluder.cs(13,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileExcluder.cs(13,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumMetadata.cs(9,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumMetadata.cs(9,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileExcluder.cs(44,31): error CS8795: Partial method ‘CesiumTileExcluder.AddToTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumTileExcluder.cs(45,31): error CS8795: Partial method ‘CesiumTileExcluder.RemoveFromTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumMetadata.cs(24,40): error CS8795: Partial method ‘CesiumMetadata.GetFeatures(Transform, int)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGlobeAnchor.cs(44,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumGlobeAnchor.cs(44,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWebMapServiceRasterOverlay.cs(10,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWebMapServiceRasterOverlay.cs(10,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWebMapServiceRasterOverlay.cs(125,41): error CS8795: Partial method ‘CesiumWebMapServiceRasterOverlay.AddToTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWebMapServiceRasterOverlay.cs(127,41): error CS8795: Partial method ‘CesiumWebMapServiceRasterOverlay.RemoveFromTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumDebugColorizeTilesRasterOverlay.cs(9,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumDebugColorizeTilesRasterOverlay.cs(9,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumDebugColorizeTilesRasterOverlay.cs(17,41): error CS8795: Partial method ‘CesiumDebugColorizeTilesRasterOverlay.AddToTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumDebugColorizeTilesRasterOverlay.cs(19,41): error CS8795: Partial method ‘CesiumDebugColorizeTilesRasterOverlay.RemoveFromTileset(Cesium3DTileset)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWgs84Ellipsoid.cs(10,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementationAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWgs84Ellipsoid.cs(10,6): error CS0246: The type or namespace name ‘ReinteropNativeImplementation’ could not be found (are you missing a using directive or an assembly reference?)
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWgs84Ellipsoid.cs(17,39): error CS8795: Partial method ‘CesiumWgs84Ellipsoid.GetRadii()’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWgs84Ellipsoid.cs(44,40): error CS8795: Partial method ‘CesiumWgs84Ellipsoid.ScaleToGeodeticSurface(double3)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWgs84Ellipsoid.cs(52,39): error CS8795: Partial method ‘CesiumWgs84Ellipsoid.GeodeticSurfaceNormal(double3)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWgs84Ellipsoid.cs(62,13): error CS8795: Partial method ‘CesiumWgs84Ellipsoid.LongitudeLatitudeHeightToEarthCenteredEarthFixed(double3)’ must have an implementation part because it has accessibility modifiers.
Library/PackageCache/com.cesium.unity@1.5.0/Runtime/CesiumWgs84Ellipsoid.cs(73,13): error CS8795: Partial method ‘CesiumWgs84Ellipsoid.EarthCenteredEarthFixedToLongitudeLatitudeHeight(double3)’ must have an implementation part because it has accessibility modifiers.
