Is it possible to install Cesium in the project , so that I can customize the C++ classes ?
Dimitrios
Dimitrios
Hi @jimver04,
Yep, you can install it to the project instead of the engine! Download a release from here (Or follow the developer setup if you’d like to be working in the repository) and place the plugin in your project folder, inside the Plugins folder. If you don’t already have a Plugins folder in the repository, you can just create one and then add Cesium for Unreal inside.
Let me know if you run into any trouble with that process.
-Alex
