➤ YN0000: ┌ Resolution step
➤ YN0000: └ Completed in 1s 550ms
➤ YN0000: ┌ Fetch step
➤ YN0013: │ rbush@npm:3.0.1 can't be found in the cache and will be fetched from the remote registry
➤ YN0013: │ topojson-client@npm:3.1.0 can't be found in the cache and will be fetched from the remote registry
➤ YN0013: │ tslib@npm:2.6.2 can't be found in the cache and will be fetched from the remote registry
➤ YN0013: │ undici-types@npm:5.26.5 can't be found in the cache and will be fetched from the remote registry
➤ YN0013: │ urijs@npm:1.19.11 can't be found in the cache and will be fetched from the remote registry
➤ YN0000: └ Completed in 0s 530ms
➤ YN0000: ┌ Link step
➤ YN0000: │ ESM support for PnP uses the experimental loader API and is therefore experimental
➤ YN0007: │ protobufjs@npm:7.2.5 must be built because it never has been before or the last one failed
➤ YN0009: │ protobufjs@npm:7.2.5 couldn't be built successfully (exit code 1, logs can be found here: /private/var/folders/7r/z2yvzrzx7_lg2h81285rsplr0000gp/T/xfs-32662a81/build.log)
➤ YN0000: └ Completed in 0s 500ms
➤ YN0000: Failed with errors in 2s 593ms
The build.log file is reporting…
# This file contains the result of Yarn building a package (protobufjs@npm:7.2.5)
# Script name: postinstall
node:internal/process/esm_loader:40
internalBinding('errors').triggerUncaughtException(
TypeError [Error]: [ERR_IMPORT_ASSERTION_TYPE_MISSING]: Module "XXXX/.yarn/unplugged/protobufjs-npm-7.2.5-3439c554a5/node_modules/protobufjs/package.json" needs an import assertion of type "json"
at load$1 (file:///XXXX/.pnp.loader.mjs:1455:17)
at nextLoad (node:internal/modules/esm/hooks:833:28)
at Hooks.load (node:internal/modules/esm/hooks:416:26)
at MessagePort.handleMessage (node:internal/modules/esm/worker:168:24)
at [nodejs.internal.kHybridDispatch] (node:internal/event_target:807:20)
at exports.emitMessage (node:internal/per_context/messageport:23:28) {
code: 'ERR_IMPORT_ASSERTION_TYPE_MISSING'
Node.js v20.9.0
I am hoping the people with the protobufjs project will chime in at some point. Otherwise, you may need to look at replacing or forking&fixing the problem in protobufjs in order to support building under Node 20. I am assuming there isn’t a technique on the Cesium side to work around the issue.
