Is this an embedded browser in a C# application? From that error message it looks like it doesn’t support some basic JavaScript functionality (like adding an event listener). Do other web applications work in this browser? Like perhaps the ThreeJS examples here: https://threejs.org/examples/#webgl_animation_cloth
Yes, it ist the default MS WebBrowser control (MS WebBrowser class documentation) embedded in a simple VB.Net application. This application is only navigating to the mentionend URL.
Yes, the ThreeJS example is running after adding the tag <meta charset="utf-8" http-equiv="X-UA-Compatible" content="IE=edge">.
Other libraries such as Openlayers run reasonably well. However, Openlayers does not respond to mouse events; these must be intercepted in VB and dealt with in JS.
Can you check if this simpler “Hello World” cesium app runs?
It would also be helpful if you can run it using the unminified version of CesiumJS to display a useful stack trace. If you need a hosted URL to run it, you can try the getting started guide here: https://cesium.com/docs/tutorials/getting-started/
I had to shorten the links so that the editor accepts the input:
TypeError: The property “update” of an undefined or null reference cannot be retrieved.
. at Viewer.prototype._onTick (…/cesiumjs/releases/1.70.1/Build/CesiumUnminified/Cesium.js:300085:5) at Event.prototype.raiseEvent (…/cesiumjs/releases/1.70.1/Build/CesiumUnminified/Cesium.js:13927:9) at Clock.prototype.tick …/cesiumjs/releases/1.70.1/Build/CesiumUnminified/Cesium.js:50085:5) at CesiumWidget.prototype.render (…/cesiumjs/releases/1.70.1/Build/CesiumUnminified/Cesium.js:293826:7) at render (…/cesiumjs/releases/1.70.1/Build/CesiumUnminified/Cesium.js:293111:13)
