I want to generate gltf with both CESIUM_primitive_outline and KHR_draco_mesh_compression extensions, but it seems the indices changes when the draco compression is applied.
Is there any workaround to apply both extensions?
Thanks
Chris
Thanks
Chris
Hey @Chris_Wang
We faced a similar issue recently and I opened (and later closed) a github issue in the draco repo to get the order of indices.
While that issue was about point clouds you could do something similar:
MESH_SEQUENTIAL_ENCODING to preserve the ordering of vertices. However this will make the compression less effective.Those are some pointers to get started. Let me know how it goes.
Hi @sean_lilley. We adopted lzma instead of Draco for compression, in order to preserve more accurate data.
Thanks again for your replay.
