Hello Support,
**Did any body have compiled ceisum terrain builder? If yes, kindly please share to me. I have some urgent requirement **
It is taking time for me to compile form the sources.
Regards,
Tharak.
Hello Support,
Regards,
Tharak.
The Cesium Terrain Builder is not affiliated with Cesium. I would ask on their GitHub page: https://github.com/geo-data/cesium-terrain-builder
The easiest way to run the Cesium Terrain Builder is to do it in Docker. If you use the image created by tumgis then you get the benefit of being able to generate quantized-mesh format tiles:
https://hub.docker.com/r/tumgis/ctb-quantized-mesh
Its dead easy to use once you have Docker installed.
