I have tried to add typescript support to the offical Webpack repo of Cesium. (https://github.com/AnalyticalGraphicsInc/cesium-webpack-example)
I just can't get it to work with the ts definitions found here: https://libraries.io/npm/cesium-typings
It compiles just fine, but an error is produced in the browser: "ReferenceError: Cesium is not defined"
I don't know how to use the definitions.
/// <reference path="typings.d.ts" />
require("cesium/Cesium")
require('cesium/Widgets/widgets.css');
// Example app
I want to use webpack with cesium and typescript.
OS: Fedora 27
Browser: Firefox 57.0.1
