Cesium World Terrain showing WHITE?
Hi… Today I find Cesium World Terrain
is showing up all WHITE, no land texture
Is there a problem? This has always worked as it should…
Cesium OSM building comes in ok and Google Photorealistic is working perfectly…
@Paul_Kueber Cesium World Terrain has no texture of its own - it’s meant to be paired with a raster overlay, such as the Bing Maps terrain overlay. Are you using one of these raster overlays? If so, which one? Also, it would help to know what Unity version and what version of Cesium for Unity you are using.
Hi… Thanks for such a quick reply…
Token Troubleshoot is ok, all green checks…
There is a Cesium Tile Set and a Cesium Ion Raster Overlay…
Using: Unity 6.2 Beta
Unity Console say thrice:
Curl error 3: URL rejected: Malformed input to a URL function
Very strange :slight_smile:
Looks like this may be an issue with using thru git hub as this issue while not working on the git hub push, is working on the original project…
Is anyone else getting this issue thru github…
The Google Photorealistic 3D Tiles and Cesium OSM Buildings are both working perfectly while,
Cesium World Terrain, has the issue where shows only white DEM with no earth…
