64>LINK : fatal error LNK1104: Cannot open file ‘…\extern\cesium-native\Cesium3DTilesContent\Debug\Cesium3DTilesContentd.lib’.
64>Builded the “CesiumForUnityNative-Runtime.vcxproj” project. - failure
65>------ Start build: Project: ALL_BUILD, Configuration: Debug x64 ------
65>Building Custom Rule C:/Users/PCN_VC/cesium-unity-samples/Packages/com.cesium.unity/native~/CMakeLists.txt
66>------ Builds skipped: Project: PACKAGE, Configuration: Debug x64 ------
66>No projects have been selected to build for this solution configuration.
67>------ Build skipped: Project: INSTALL, Configuration: Debug x64 ------
67>No projects have been selected to build for this solution configuration.
========== Builds: 63 successful, 2 failed, 0 up to date, 2 skipped ==========
========== The build started at 3:16 PM and took 03:20.562 minutes ==========
LINK : fatal error LNK1104: ‘…\extern\cesium-native\Cesium3DTilesContent\Debug\Cesium3DTilesContentd.lib’ 파일을 열 수 없습니다.
64>“CesiumForUnityNative-Runtime.vcxproj” 프로젝트를 빌드했습니다. - 실패
65>------ 빌드 시작: 프로젝트: ALL_BUILD, 구성: Debug x64 ------
66>------ 건너뛴 빌드: 프로젝트: PACKAGE, 구성: Debug x64 ------
66>이 솔루션 구성에 대해 빌드하도록 선택된 프로젝트가 없습니다.
67>------ 건너뛴 빌드: 프로젝트: INSTALL, 구성: Debug x64 ------
67>이 솔루션 구성에 대해 빌드하도록 선택된 프로젝트가 없습니다.
========== 빌드: 63개 성공, 2개 실패, 0개 최신 상태, 2개 건너뜀 ==========
========== 빌드이(가) 오후 3:16에 시작되었고 03:20.562 분이(가) 소요됨 ==========
I tried to solve this problem for 10 days at home and at work, but was not successful. How can I solve this problem?
The error that appears in Unity is like this.
NotImplementedException: The native implementation is missing so Update cannot be invoked. This may be caused by a missing call to CreateImplementation in one of your constructors, or it may be that the entire native implementation shared library is missing or out of date.
CesiumForUnity.Cesium3DTileset.Update () (at Reinterop/Reinterop.RoslynSourceGenerator/Cesium3DTileset-generated.cs:103)
