Cesium's Camera in 3D
I realize a flight simulator and I use Cesium's "Camera" with Bing Maps images to show what we see outside the plane.
Unhappily, the picture seems to be "flat", not in 3D.
For example, have a look at position 48.863466N, 2.301881E, height 100m,
heading 230°, pitch 10°. You will see the shade of Eiffel Tower on river Seine, but not Eiffel Tower itself.
If you use Bing Maps directly at the same position, you see it very well.
How is it possible to correct this problem ?
Thank you very much for your help.
homeCamera = {
  orientation : {
    heading : Cesium.Math.toRadians(Heading),
    pitch : Cesium.Math.toRadians(Pitch),
    roll : Cesium.Math.toRadians(Roll)
viewer.camera.setView(homeCamera);
Cesium's version is the latest one (1.42 I presume). I use a PC with Windows 7 and Firefox 58.0.2 (latest version).
Hi Jean Pierre,
Bing Maps is an Imagery Layer, which means it is a flat image that is “draped” over the globe and terrain. You can use a 3D Model of the Eiffel Tower, see the 3D Models Sandcastle example for how to load in a model.
Gabby
