Hi!
I am a beginner with Cesium.
I am trying to use "shadow example" like my base map.
I want to transform the original "locations" (Exton, Everest, etc...) code in new Locations:
The first one: 28.411617° N 16.32725° W
The second one: 28.467404° N 16.2469334° W
(Both in Tenerife Island)
I tried to put my latitudes and longitudes in the code, changing with "Exton" or "Everest".... but it doesn´t work.
Please, help me!
infoBox : false,
selectionIndicator : false,
shadows : true,
terrainShadows : true
viewer.terrainProvider = new Cesium.CesiumTerrainProvider({
url : '//assets.agi.com/stk-terrain/world',
requestWaterMask : true,
requestVertexNormals : true
var shadowMap = viewer.shadowMap;
shadowMap.maxmimumDistance = 10000.0;
var cesiumAir = viewer.entities.add({
height : 20.0,
model : {
uri : '../../SampleData/models/CesiumAir/Cesium_Air.glb'
var groundVehicle = viewer.entities.add({
name : 'Ground Vehicle',
height : 0.0,
model : {
uri : '../../SampleData/models/CesiumGround/Cesium_Ground.glb'
var cesiumMan = viewer.entities.add({
height : 0.0,
model : {
uri : '../../SampleData/models/CesiumMan/Cesium_Man.glb'
var woodTower = viewer.entities.add({
height : 0.0,
model : {
uri : '../../SampleData/models/WoodTower/Wood_Tower.gltf'
var simpleCity = viewer.entities.add({
height : 0.0,
model : {
uri : '../../SampleData/models/ShadowTester/Shadow_Tester_4.gltf'
var locations = {
Exton : {
longitude : -1.31968, //here I try to make changes, with new longitude and latitude. I don´t which is the systen of latitude-longitude that Cesium uses :(//
latitude : 0.698874,
height : 374.14210186070714,
date : 2457522.154792
HalfDome : {
longitude : -2.086267733294987,
latitude : 0.6587491773830219,
height : 2640.716312584986,
date : 2457507.247512
Everest : {
longitude : 1.517132688,
latitude : 0.4884844964,
height : 8773.17824498951,
date : 2457507.620845
PinnaclePA : {
longitude : -1.3324415110874286,
latitude : 0.6954224325279967,
height : 179.14276256241743,
date : 2457523.041620
SenecaRocks : {
longitude : -1.3851775172879768,
latitude : 0.6778211831093554,
height : 682.5893300695776,
date : 2457522.097512
Space : {
height : 2000000.0,
var i;
var entities = viewer.entities.values;
var entitiesLength = entities.length;
function setLocation(location) {
var longitude = location.longitude;
var latitude = location.latitude;
var height = location.height;
for (i = 0; i < entitiesLength; ++i) {
var entity = entities[i];
entity.position = Cesium.Cartesian3.fromRadians(longitude, latitude, height + entity.height);
viewer.clock.currentTime = new Cesium.JulianDate(location.date);
viewer.clock.multiplier = 1.0;
function setLocationFunction(location) {
return function() {
setLocation(location);
var locationToolbarOptions = ;
for (var locationName in locations) {
if (locations.hasOwnProperty(locationName)) {
var location = locations[locationName];
locationToolbarOptions.push({
text : locationName,
onselect : setLocationFunction(location)
Sandcastle.addToolbarMenu(locationToolbarOptions);
function setEntity(entity) {
entities[i].show = false;
entity.show = true;
function setEntityFunction(entity) {
return function() {
setEntity(entity);
var entityToolbarOptions = ;
entityToolbarOptions.push({
text : entity.name,
onselect : setEntityFunction(entity)
Sandcastle.addToolbarMenu(entityToolbarOptions);
Sandcastle.addToolbarButton('Toggle Shadows', function() {
viewer.shadows = !viewer.shadows;
Sandcastle.addToolbarButton('Toggle Terrain Shadows', function() {
viewer.terrainShadows = !viewer.terrainShadows;
Sandcastle.addToolbarButton('Soft Shadows', function() {
shadowMap.softShadows = !shadowMap.softShadows;
Sandcastle.addToolbarMenu([{
text : 'Size : 2048',
onselect : function() {
shadowMap.size = 2048;
text : 'Size : 1024',
shadowMap.size = 1024;
text : 'Size : 512',
shadowMap.size = 512;
text : 'Size : 256',
shadowMap.size = 256;
function setShadows(castShadows, receiveShadows) {
entities[i].model.castShadows = castShadows;
entities[i].model.receiveShadows = receiveShadows;
text : 'Entity Shadows',
setShadows(true, true);
text : 'Cast Only',
setShadows(true, false);
text : 'Receive Only',
setShadows(false, true);
text : 'Off',
setShadows(false, false);
setLocation(locations.Exton);
setEntity(cesiumAir);
