Change points' color over / based on time
is there a way to change points’ color over time with something like ColorMaterialProperty used with the material property of polygons - Material example
I need colors to fade over time but have to use points instead of polygons because of optimization.
Thank you very much.
Welcome to the Cesium Community, @Kiailandi!
PointGraphics also have a color property which you can change, similar to the polygon’s material property.
Hi @dzung, thanks for the welcome.
I get that color can change, but I am unable to find the equivalent of ColorMaterialProperty for color.
With ColorMaterialProperty I can use both a CallbackProperty and TimeIntervalCollectionProperty to change the material based on time, but I don’t see how can I do the same with the color, as it seems to accept only straight up colors in the constructor.
Thanks for any help you can give on the matter.
Can you post an example of what you’re trying to do in Sandcastle? That usually makes it a lot easier to help out.
I came up with this super simple example that uses a CallbackProperty to return a different color based on if the current second is even or odd. Is that what you were looking for?
I’d like to do something like this but using a point instead of a box (start cesium timer and increase time speed to see the effect).
The core idea is that the color should fade over time based on an iterval.
It’s not exactly what I’m trying to do as I am working with cesium time intervals, but I can probably expand this example and make it work.
Thank you.
(If you have any other suggestion based on the new sandcastle example I posted please share them, I would be grateful)
Your example works perfectly if you just don’t wrap the TimeIntervalProperty in a ColorMaterialProperty, i.e.
viewer.entities.add({
    position: Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883),
    point: {
      color : createTimeIntervalCollectionProperty('#ff00ff', 0, refreshRate),
      pixelSize: 10,
Well, I don’t really know what I did wrong in my project but it wasn’t working.
At least now I know that it works and if it doesn’t I have to search elsewhere for the problem.
Thank you very much for the help!
