Hi all,
I’ve been trying to find a way to change the globe’s tileset at runtime, similar to how you normally layer a map. Specifically, it’s between the night map, the normal aerial view, and the aerial view + labels.
Is it possible to do such a thing? I’m assuming it would mean re-loading the whole globe, but currently the only way I see how is via the editor, either by pressing “Use this as Tileset base layer” or by quick adding from the cesium menu.
Just a quick edit -
I see that each asset supposedly has a cesium ion id on the 3D tileset component, but for me the three of them are 1.
Thanks!
