Clamping Billboard to ground with Terrain enabled
If you go to: https://spatialillusions.com/Demos/cesium/ and turn on STK terrain you will see that the billboard military symbols are being clipped in half.
My issue is very similar. I am getting the entity elevation information from a DIS simulations, but trying to show it on with the STK terrain, which has different heights, I figured I could do a clamp to ground, and that would fix it, but I get the same result as the folks from spatial illusions
I tried this type of solution: https://groups.google.com/forum/embed/?place=forum/cesium-dev&showsearch=true&showpopout=true&hideforumtitle=true&fragments=true&parenturl=https%3A%2F%2Fcesiumjs.org%2Fforum%2F#!searchin/cesium-dev/billboard$20clamp/cesium-dev/PsfINmAvdmA/hazPRQ6UEQAJ
terrainProvider = viewer.terrainProvider;
viewer.terrainProvider = new Cesium.CesiumTerrainProvider({
   url : '[https://assets.agi.com/stk-terrain/v1/tilesets/world/tiles](https://assets.agi.com/stk-terrain/v1/tilesets/world/tiles)'
viewer.scene.globe.depthTestAgainstTerrain = true;
viewer.entities.add({
   position : Cesium.Cartesian3.fromDegrees(-122.1958, 46.1915),
   billboard : {
       image : '../images/facility.gif',
       heightReference : Cesium.HeightReference.CLAMP_TO_GROUND,
Right now, I can just bias the altitude by 500 meters, and it is a crude but workable solution. But I would like to fix it. The full code for adding a glyph is below:
Enter code here… makeGlyph(sprite) {
let milSym = milSymbols[sprite.type]
if (milSym === undefined) milSym = milSymbols[“UFO”]
sprite.symbol = milSym
let sym2 = new ms.Symbol(milSym, { size: 28, type: sprite.marking, speed: ‘5 kph’, direction: 90, infoColor: “red” })
let glyph = new Cesium.Entity({
position: Cesium.Cartesian3.fromDegrees(sprite.lon, sprite.lat, sprite.altitude + 500.0),
billboard: {
image: sym2.asCanvas(), //Get the canvas for the billboard
// heightReference : Cesium.HeightReference.CLAMP_TO_GROUND,
pixelOffset: new Cesium.Cartesian2(-sym2.markerAnchor.x, -sym2.markerAnchor.y), // Symbol offset
eyeOffset: new Cesium.Cartesian3(0.0, 0.0, 0.0), // default
horizontalOrigin: Cesium.HorizontalOrigin.LEFT, // default
verticalOrigin: Cesium.VerticalOrigin.TOP
label: {
text: sprite.marking,
font: ‘14pt monospace’,
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
outlineWidth: 1,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
pixelOffset: new Cesium.Cartesian2(0, -20)
sprite.glyph = glyph
this.viewer.entities.add(glyph)
Cesium 1.39, Chrome 61
Hi there,
I see you are setting the billboard’s verticalOrigin to the top:
Do you have any luck setting it to the bottom?
Gabby
Forgot to link to the documentation:
Billboard.verticalOrigin
Yes, Much better, Thank you
