Connect to Cesium Ion button not launching web browser
When trying to connect to cesium Ion from the USD composer, every time I click the “Connect to Cesium ion” button, it launches a windows explorer vs. the web login page. Tried USD Composer 2023.2.4 and 2023.2.5 and using the 0.24.0 Cesium plugin with the 0.6.0 Cesium USD plugin. Anyone know what’s going on? Thanks!
Have now tried this on another computer with Issac Sim 4.5 and still the same problem. Can anyone help?
Another piece of info is that when I click the button, I also get some more buttons below that say open browser again and copy URL into browser. But in this case, there is no URL in the URL input field. Maybe that’s why it’s opening in the windows explorer. But then how do I fix that issue?
@ARN sorry for the delay on this response. If it is opening windows explorer when you go to log in, that sounds like your systems default application for URL’s is set to Windows Explorer?
If you go to Settings > Apps > Default Apps, can you confirm http is set to a web browser, like below?
Yeah, I checked that, but that doesn’t seem to be it.
Hello all,
For others who run into this problem, I replaced the “cacerts” certificate file in the extension’s “certs” folder and mine starting working again. It may also be your proxy settings as well.
Good Luck!
I named the replacement certificate as the same name as the one being replaced, by the way!
