I have a Javascript Image() object that I’ve successfully loaded from a CORS-enabled server, but when I attempt to use that image as the “image” member for a Billboard object, I get this error:
Billboard.js:952 Error loading image for billboard: SecurityError: Failed to execute ‘texSubImage2D’ on ‘WebGLRenderingContext’: The cross-origin image at [myImageURL] may not be loaded.
This is really strange, because I’ve already successfully loaded it into a JS Image() object. Why would this be a problem?
Dave
Found the solution to my problem (supported in at least FireFox and Chrome).
// Before setting the .src of the image, set:
myImage.crossOrigin = ‘anonymous’;
Explained nicely here:
https://hacks.mozilla.org/2011/11/using-cors-to-load-webgl-textures-from-cross-domain-images/
Yes, images are not loaded with CORS by default. You can also use Cesium’s loadImage function which handles CORS as well as adapting the Image callback to a Promise, which is commonly used in Cesium.
http://cesiumjs.org/Cesium/Build/Documentation/loadImage.html
