I downloaded Cesiumjs-1.11 and ran the official Hello World tutorial.
I want to run the same example without relying on nodejs as a server. I tried taking the ./Build/Cesium and using it with the example in the same directory.
CesiumJS runs, but I get this error:
SecurityError: Failed to execute 'texImage2D' on 'WebGLRenderingContext': The cross-origin image at file:://path/to/Cesium/Assets/Textures/moonSmall.jpg may not be loaded.
at Error (native)
at new p (file:://path/to/Cesium/Cesium.js:433:19773)
at et.createTexture2D (file:://path/to/Cesium/Cesium.js:449:19216)
at H.update (file:://path/to/Cesium/Cesium.js:434:9600)
at S.update (file:://path/to/Cesium/Cesium.js:452:1298)
at m.update (file:://path/to/Cesium/Cesium.js:455:27828)
at vt (file:://path/to/Cesium/Cesium.js:458:15322)
at Ct (file:://path/to/Cesium/Cesium.js:458:18817)
at bt.render (file://path/to/Cesium/Cesium.js:458:25057)
at P.render (file:://path/to/Cesium/Cesium.js:464:4108)
Here is the code:
<!DOCTYPE html>
<html lang="en">
<head>
<!-- Use correct character set. -->
<meta charset="utf-8">
<!-- Tell IE to use the latest, best version (or Chrome Frame if pre-IE11). -->
<meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1">
<!-- Make the application on mobile take up the full browser screen and disable user scaling. -->
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>Hello World!</title>
<script src="Cesium/Cesium.js"></script>
<style>
@import url(Cesium/Widgets/widgets.css);
html, body, #cesiumContainer {
width: 100%; height: 100%; margin: 0; padding: 0; overflow: hidden;
</style>
</head>
<body>
<div id="cesiumContainer"></div>
<script>
</script>
</body>
</html>
What’s wrong with this code ? (I need to embed Cesium-1.11 in a standalone app and I don’t want to add a server dependency to my app).
