Country JSON File
I need to load all countries JSON File in GeoJsonDataSource.load.How can I get this source file? Can you please provide the all counties JSON file?
I have downloaded the ne_10m_admin_0_countries2.json file from forums support but I am getting the below error in console.
undefined
DeveloperError: normalized result is not a number
Error
at new DeveloperError (http://localhost/Cesium-1.58/Source/Core/DeveloperError.js:43:19)
at Function.Cartesian3.normalize (http://localhost/Cesium-1.58/Source/Core/Cartesian3.js:421:19)
at Ellipsoid.geodeticSurfaceNormalCartographic (http://localhost/Cesium-1.58/Source/Core/Ellipsoid.js:353:27)
at Ellipsoid.cartographicToCartesian (http://localhost/Cesium-1.58/Source/Core/Ellipsoid.js:390:14)
at Object.PolygonGeometryLibrary.subdivideRhumbLine (http://localhost/Cesium-1.58/Source/Core/PolygonGeometryLibrary.js:212:31)
at createGeometryFromPositions (http://localhost/Cesium-1.58/Source/Core/PolygonOutlineGeometry.js:90:60)
at Function.PolygonOutlineGeometry.createGeometry (http://localhost/Cesium-1.58/Source/Core/PolygonOutlineGeometry.js:555:36)
at createPolygonOutlineGeometry (http://localhost/Cesium-1.58/Source/Workers/createPolygonOutlineGeometry.js:16:39)
at createGeometry (http://localhost/Cesium-1.58/Source/Workers/createGeometry.js:47:40)
at callAndWrap (http://localhost/Cesium-1.58/Source/Workers/createTaskProcessorWorker.js:20:31)
/This is my current code/
var highlightedEntity;
var highlightColor = Cesium.Color.YELLOW.withAlpha(0.6);
var normalColor = Cesium.Color.SLATEGREY.withAlpha(0.6);
//A property that returns a highlight color if the entity is currently moused over, or a default color otherwise.
function createCallback(entity){
var colorProperty = new Cesium.CallbackProperty(function(time, result){
if(highlightedEntity === entity){
return Cesium.Color.clone(highlightColor, result);
return Cesium.Color.clone(normalColor, result);
}, false);
return new Cesium.ColorMaterialProperty(colorProperty);
var promise = Cesium.GeoJsonDataSource.load(’…/…/SampleData/ne_10m_admin_0_countries2.json’);
promise.then(function(dataSource) {
//Get the array of entities
for (var i = 0; i < entities.length; i++) {
var entity = entities[i];
entity.polygon.material = createCallback(entity);
}).otherwise(function(error){
//Display any errrors encountered while loading.
window.alert(error);
var scene = viewer.scene;
var handler = viewer.screenSpaceEventHandler;
handler.setInputAction(function(movement) {
var pickedObject = scene.pick(movement.endPosition);
if (Cesium.defined(pickedObject) && pickedObject.id instanceof Cesium.Entity) {
highlightedEntity = pickedObject.id;
} else{
highlightedEntity = undefined;
  • I want to highlight the country when hovering over the county and appears the country name also.
  • I need to load all countries JSON File in GeoJsonDataSource.load.How can I get this source file? Can you please provide the all counties JSON file?
  • I have downloaded the ne_10m_admin_0_countries2.json file from forums support but I am getting the below error in console.
  • Is it possible to set URL on click of any country? How can I achieve this? Which Parameter do we need to pass in the JSON Data?
  • **Cesium Version: 1.58
  • Browser: Google Chrome
  • Operating System: Windows**
Below Code is working for the US states
}, false);
var promise = Cesium.GeoJsonDataSource.load(’…/…/SampleData/ne_10m_us_states.topojson’);
} else{
ne_10m_us_states.topojson (73.4 KB)
Can you post the JSON file that’s producing this error? It might be related to this issue: https://github.com/AnalyticalGraphicsInc/cesium/issues/7864
Where this GeoJSON of all the countries used to work in CesiumJS 1.53.
