Hello, we have problem with older Ipad and Iphone on these two IOS versions.
memory overloads causing WebGL crash.
Regarding devices affected:
They are different: iPad 9, iPhone mini, iPhone XR, iPhone SE 2022, iPhone SE 2020,
iPhone 11, iPhone 11 Pro, iPhone SE 2, Ipad Pro 11 2nd generation, iPad Pro, iPad 9th Generation
IOS versions 18.2, 18.3.
You can replicate it by clicking on any aircraft icon over the map, and then clicking 3d view tab in the bottom of aircraft panel.
Maybe any of you have similar issue?
Same in your demo project
Additional Information (Follow-up)
Just to supplement my original post with more specific insights:
We’ve confirmed that this issue reproduces reliably across the following Apple devices, all running iOS 18.2 or 18.3:
- iPad 9th Generation
- iPad Pro (11-inch, 2nd Gen)
- iPhone SE (2020, 2022)
- iPhone 11, 11 Pro
- iPhone XR
- iPhone Mini
Symptoms: WebGL context is lost shortly after CesiumJS initializes the 3D scene. The error appears as:
vbnet
CopyEdit
WebGL: context lost.
TypeError: null is not an object (evaluating 'h[0]')
This seems tied to GPU memory allocation or context limits on newer iOS versions. Our stack trace shows the crash deep within Cesium’s WebGL layer, during the creation of imagery providers and scene setup.
Steps to Reproduce (recap):
- Open: Live Flight Tracker - Real-Time Flight Tracker Map | Flightradar24
- Click on any aircraft icon.
- In the bottom panel, switch to the “3D view” tab.
The crash occurs within seconds on the affected iOS versions.
Notes:
- Issue does not occur on Android or older iOS versions (e.g. iOS 17.x).
- No abnormal memory consumption is observed in dev tools before the crash.
- Behavior is consistent across multiple device models, indicating a platform-level regression or change.
Has anyone observed new WebGL limits or GPU context behaviors in iOS 18.2/18.3? Any known CesiumJS tweaks to mitigate context loss under these conditions would be hugely appreciated.
Thanks again!
Also
You can open example project.
Same in IOS 18.4 and 18.4.1
Devices
- 18.4.1 - iPhone 11Pro Max
- 18.3.2 - iPhone12
- 18.4.1 - iPhone12
- 18.3.2 - iPhone12
- 18.3.2 - iPhone12
- 18.3.1 - Iphone 11
- 18.4.1 - iPhone SE (2nd Gen)
- 18.4.1 - iPad 12
- 18.4.1 - iPad 8
- 18.4.1 - iPad 12
Thank you Ioseb actually we are facing the same issue on an iphone 11 IOS.18.5. and iphone SE…but we have also two iphone12 pro
12 Pro IOS 18.5 (bug)
12 Pro IOS 18.4.1 (ok)
Do you know if there is any chance to patch this problem ?
Answer from webkit
The site is causing a kIOGPUCommandBufferCallbackErrorHang due to the large amount of work being submitted.
Prior to 257584 – [ANGLE] Lose Metal-backed context we would ignore such errors.
The fact the site appeared to work while receiving kernel errors is relying on undocumented kernel behavior.
Could you split up your command buffers by calling WebGLRenderingContext.flush()? This will result in the MTLCommandBuffer getting its commit member function called - commit() | Apple Developer Documentation
WebKit / ANGLE does not split up the command buffers implicitly as we don’t without substantial analysis have the context to identify how much work is contained within them.
