Create Collection of Pins and ArcSplines, render them and being able to address them later
Hi guys,
Basically I want to mention, that I am a Beginner with Cesium.
Anyways, I am currently working on an app, which gets Points where I need to draw Pins. Additionally from another Startpoint I draw an Arc to each Pin.
I actually use following approach:
I calculate the Polylinepoints sequentially with a CatmullRomSpline and add them afterwards to a PolylineCollection:
var polylineCollection = new Cesium.PolylineCollection();
var polyline = polylineCollection.add({
      positions : polylinePoints,
      width : calculateArcWidth(start,end)
    polyline.material = new Cesium.Material({
      fabric : {
        type : 'PolylineGlow',
        uniforms : {
          color : cesiumColor
My target is to calculate these arcs in advance and then to render them all afterwards. I achieve this by adding them to the scene by:
scene.primitives.add(polylineCollection);
My Problem now is, that I didn't find an approach like the shown one for the Pins.
At the moment I create the Pins as follows:
var pinBuilder = new Cesium.PinBuilder();
var Pin = Cesium.when(pinBuilder.fromUrl('Cesium/Assets/Textures/maki/post.png', Cesium.Color.WHITE, 48), function(canvas) {
      return viewer.entities.add({
        description : post.message,
        fbfeed: new FBfeed("post",user.content,post),
        position : Cesium.Cartesian3.fromDegrees(post.place.location.longitude, post.place.location.latitude),
        billboard : {
          image : canvas.toDataURL(),
          verticalOrigin : Cesium.VerticalOrigin.BOTTOM,
          color : cesiumColor
        point: {
          pixelSize: 5,
          color: cesiumColor,
          outlineColor: Cesium.Color.WHITE,
          outlineWidth: 2
With this code snippet, the Pins were all created at the moment of call.
I'd like to store them in a datastructure to be able to later decide to render them or not.
Additionally I am struggeling with that point, that lateron I also want to be able to toggle rendering of sets of arcs and all associated pins and identify them by an id.
So basically I'd like to have a structure looking like that:
renderData: {
    pinCollection: <PinCollection>,
    polylineCollection: <polylineCollection>,
    render: <true/false>
to be able to search for an ID, and toggle render to display/hide or render/delete from scene.
I'd appreciate any kind of help,
I wasn't able to find related tutorials, demos or questions/discussions which could possibly help me.
I think my target isn't a big Deal, probably anyone knows an easy solution for that?
Thank you in advance!
Best regards,
Nico
Hello Nico,
You can add your pins using a BillboardCollection. This is what is happening behind the scenes when you use entities.add.
Similarly, if you need to add points you can use a PointPrimitiveCollection
Hannah
Hi Hannah!
thank you very much, you have directed me into the right direction.
I now use a CustomDataSource where I have added all EntityCollections.
Afterwards I add them to viewer.dataSources and save the return as Reference:
let dataSource = new Cesium.CustomDataSource(user.name);
for (var i = 0; i < user.renderData.posts.length; i++) {
dataSource.entities.add(user.renderData.posts[i]);
let dataReference = viewer.dataSources.add(dataSource);
user.renderData.reference = dataReference;
Is there a possibility to toggle the show attribute (as documented it should be only a getter mehtode, but a proposal to change this has been accepted here.),
or do I have to add the source and remove it everytime I want to toggle show? (like here)
This would help me to finish my project :slight_smile:
Nico
