First I would like to thank you for cesium. It's great tool and it's one of the best open source projects I saw.
my problem:
I implemented custom datasource which is kind of vector tile datasource.
In every update call, there is a check based on camera properties and new datasource instance is made for every new "tile". Not relevant datasource instances are removed.
This works just fine, but after some minutes of camera movement I see the viewer "stutter" and eventually completely stop.
Profiling indicates that the garbage collection is the reason.
I think to make "object pooling", as described here:
But before I'm starting I want to ask if you have any experience with such situations and if you have any recommendations/best practices/approaches which could solve this problem.
If object pooling is also your recommendation, which objects are most important to recycle?
Thank you very much
