I am trying to run the Custom Geocoder that is in Sandcastle…
However, it never works.
This is because the minute I enter anything into the search box, the Geocoder starts running, while the query term is still incomplete.
For example, if I try to enter “San Francisco”, I need to type extra fast, but still I only get “San F” before the following code runs:
OpenStreetMapNominatimGeocoder.prototype.geocode = function (input) {
var endpoint = 'https://nominatim.openstreetmap.org/search?’;
var query = ‘format=json&q=’ + input;
var requestString = enpoint + query;
So the result says “not found” because there is no city named San F.
I need to implement a custom geocoder, using the Cesium input box.
Ideally I would like to adapt to Google API Geocoder.
I am using Cesium 1.38, with Google Chrome 61 on mac (64 bit)
Thanks for any help!!
