I have developed a reverse geocoder for Cesium using the BingMaps API. It works perfectly in my html page, running locally on my Cesium server.
I was thinking of checking it in as a Sandcastle example…it works around CORS which BingMaps doesn’t support.
But the call fails every time. Is this expected? Or am I missing something?
**** var requestString = “http://dev.virtualearth.net/REST/v1/Locations/” + latitude + “,” + longitude + “?jsonp=GeocodeCallback&key=”;
// Call the Cesium jsonp
Cesium.loadJsonp(requestString).then(function(data) {
console.log(“Success in getting response”);
}).otherwise(function(error) {
**console.log("Error in getting response: " + error); ** //It always ends up here…
When I run it in my html page on the local server, it works only with my key, and not with the Cesium default key…
In Sandcastle, it doesn’t work no matter which key I use.
I am using as a starting point the “HelloWorld” Sandcastle example.
The specification for the reverse geocoder, is:
If the user clicks any location on the map, the location will be marked by a red point, and the address (or zip code if no address) will show in the entity label.
Version 1.39, Mac Sierra, Chrome
