Hi, are they any special precautions we need to take when deleting georeferenced levels?
Hello @UnrealVistas ,
Deleting a georeferenced sublevel should be straightforward. You may want to delete the corresponding georeference entry in the sublevels list on the CesiumGeoreference as well, in case there is a new level you create later with the same name as the old one. Just as with any level in Unreal, you may want to double-check there’s nothing in the sublevel you care for keeping before deciding to delete. It should not affect the rest of the georeference system or the other sublevels though!
