I have download the source code which called ‘cesium-main’.
I use command ‘npm run build’ and ‘npm run build-docs’ and ‘npm run start’,then I open the local website on ‘http://localhost:8080’,it works successful.
however,in the local network,those sandcastle pages such as ‘http://localhost:8080/Apps/Sandcastle/index.html’,does not show map image.I have deploy a tile map image server with nginx,how can I config it into source code?thank you very much.
Hi there,
Where did you download the source code from? GitHub, cesium.com, or npm?
Is there any error in the console?
thank you for your suggests,I have successfully started the doc website.
I just don’t know how to modify the source code,that can change imageryProvioder’s Url from public internet url such as ‘http://ecn.t3.tiles.virtualearth.net/tiles/a201.jpeg?n=z&g=13317’ to a private local tile image url such as 'http://localhost:8081/map/{x}/{y}/{z}.
I have exprience to use local tile image in myself cesium map project.
I would recommend reading our Imagery Tutorial to get started. Thanks!
