Description remove properties from Infobox
I have a JSON file with all the data that I need. I would like after this to able to pull data from the Database. After putting a description of my entity it removes properties and others without descriptions are showing them as they should. What am I missing?
“type”: “FeatureCollection”,
“features”: [
{ “type”: “Feature”,
“geometry”: {“type”: “Point”,“coordinates”: [80.2066734649931, 13.0187039189613]}, “color”:{
“rgba”:[0,0,255,95]},
“properties”: {
“Name”: “Mika”,
“Age”: 17,
“Type”: “Policeman”,
“description”:“PICTURE:
“geometry”: {“type”: “Point”,“coordinates”: [ 120.2072495864164, 34.0191043036246]},
“properties”: {
“Name”: “Zika”,
“Age”: “Worker”
“geometry”: { “type”: “Point”,“coordinates”: [ 140.2067574402883, 84.0191983952581]},
“properties”: {
“Name”: “Pera”,
“Age”: 23,
“Type”: “Student”
I already made a form that users can fill with name, age, and image that will go to the Database and place a pin on the map.
I’m using Cesium 1.58.1 on Windows 10
I think the problem here is that “description” is a Simple Style identifier (see https://github.com/mapbox/simplestyle-spec/tree/master/1.0.0) so it overrides the other properties you have.
Here’s a Sandcastle where I changed it to an uppercase “Description” to get around that. You should be able to see all the properties now. Hope that helps!
