Good evening,
I puzzled over this throughout the afternoon. Why do unitQuaternions behave differently between czml's "orientation" property and a czml model's "nodeTransformation" property.
The following Sandcastle code shows Cesium_Man.glb using both forms of unitQuaternion. Between 2AM and 10AM, I would expect him to change his heading 90degrees, but instead he jumps dramatically to his left before rotating forward about his hips.
The second form of unitQuaternion uses the nodeTransformation>rotation form of unitQuaternions and this movement is what I would expect. The neutral 0,0,0,1 (x,y,z,w) values rotates 90degrees to 0,1,0,0 before rotating back to the starting point.
This appears to have caused confusion on the forum in the past, and I see some resolutions using matrices. Using CZML, how can I make the first form of "orientation" unitQuaternions behave like the second (in other words, rotate to face the camera while staying vertical)?
Cheers, e
var czml = [{
"id" : "document",
"name" : "CZML Model",
"version" : "1.0",
"clock": {
"interval": "2017-01-19T00:00:00Z/2017-01-19T23:59:59Z",
"id" : "model",
"position" : {
"cartographicDegrees" : [-77, 37, 100000]
"orientation":{
"interpolationAlgorithm": "LINEAR",
"interpolationDegree": 1,
"unitQuaternion": [
"2017-01-19T02:00:00Z",0,0,0,1,
"2017-01-19T06:00:00Z",0,0,0,1,
"2017-01-19T10:00:00Z",0,0,1,1
"model": {
"gltf" : "../../SampleData/models/CesiumMan/Cesium_Man.glb",
"runAnimations":false,
"nodeTransformations": {
"Skeleton_arm_joint_R__2_": {
"rotation": {
"unitQuaternion":[
"2017-01-19T14:00:00Z",0,0,0,1,
"2017-01-19T18:00:00Z",0,1,0,0,
"2017-01-19T22:00:00Z",0,0,0,1
var promise = viewer.dataSources.add(Cesium.CzmlDataSource.load(czml));
promise.then(function(dataSource){
viewer.trackedEntity = dataSource.entities.getById('model');
}).otherwise(function(error){
window.alert(error);
