Hi everyone
I am trying to draw some vector tiles by using QuadtreePrimitive in the Sandcastle demo of Cesium 1.16.
It works in 1.16, but the performance is not good (it will draw lots of rectangles in very detailed levels), I think the problem might be an improper geometricError, but I don’t know how to change the geometricError in each level to draw less rectangles.
Another problem is the code in 1.16 sandcastle doesn’t work in 1.32. It doesn’t draw rectangles anymore.
var DemoTileProvider = function() {
this._quadtree = undefined;
this._tilingScheme = new Cesium.GeographicTilingScheme();
this._errorEvent = new Cesium.Event();
this._levelZeroMaximumError = Cesium.QuadtreeTileProvider.computeDefaultLevelZeroMaximumGeometricError(this._tilingScheme);
Object.defineProperties(DemoTileProvider.prototype, {
quadtree : {
get : function() {
return this._quadtree;
set : function(value) {
this._quadtree = value;
ready : {
get : function() {
return true;
tilingScheme : {
get : function() {
return this._tilingScheme;
errorEvent : {
get : function() {
return this._errorEvent;
DemoTileProvider.prototype.beginUpdate = function(frameState) {
DemoTileProvider.prototype.endUpdate = function(frameState) {
DemoTileProvider.prototype.getLevelMaximumGeometricError = function(level) {
return this._levelZeroMaximumError / (1 << level);
DemoTileProvider.prototype.loadTile = function(frameState, tile) {
if (tile.state === Cesium.QuadtreeTileLoadState.START) {
tile.data = {
primitive : undefined,
freeResources : function() {
if (Cesium.defined(this.primitive)) {
this.primitive.destroy();
this.primitive = undefined;
var color = Cesium.Color.fromBytes(255, 0, 0, 255);
if(tile.rectangle.west>=-Cesium.Math.PI&&tile.rectangle.east<=Cesium.Math.PI){ //Here is the code I add to make it work in Cesium 1.16
tile.data.primitive = new Cesium.Primitive({
geometryInstances : new Cesium.GeometryInstance({
geometry : new Cesium.RectangleOutlineGeometry({
rectangle : tile.rectangle
attributes : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(color)
appearance : new Cesium.PerInstanceColorAppearance({
flat : true
tile.data.boundingSphere3D = Cesium.BoundingSphere.fromRectangle3D(tile.rectangle);
tile.data.boundingSphere2D = Cesium.BoundingSphere.fromRectangle2D(tile.rectangle, frameState.mapProjection);
Cesium.Cartesian3.fromElements(tile.data.boundingSphere2D.center.z, tile.data.boundingSphere2D.center.x, tile.data.boundingSphere2D.center.y, tile.data.boundingSphere2D.center);
tile.state = Cesium.QuadtreeTileLoadState.LOADING;
if (tile.state === Cesium.QuadtreeTileLoadState.LOADING) {
tile.data.primitive.update(frameState);
if (tile.data.primitive.ready) {
tile.state = Cesium.QuadtreeTileLoadState.DONE;
tile.renderable = true;
DemoTileProvider.prototype.computeTileVisibility = function(tile, frameState, occluders) {
var boundingSphere;
if (frameState.mode === Cesium.SceneMode.SCENE3D) {
boundingSphere = tile.data.boundingSphere3D;
} else {
boundingSphere = tile.data.boundingSphere2D;
return frameState.cullingVolume.computeVisibility(boundingSphere);
DemoTileProvider.prototype.showTileThisFrame = function(tile, frameState) {
var subtractScratch = new Cesium.Cartesian3();
DemoTileProvider.prototype.computeDistanceToTile = function(tile, frameState) {
var boundingSphere;
} else {
return Math.max(0.0, Cesium.Cartesian3.magnitude(Cesium.Cartesian3.subtract(boundingSphere.center, frameState.camera.positionWC, subtractScratch)) - boundingSphere.radius);
DemoTileProvider.prototype.isDestroyed = function() {
return false;
DemoTileProvider.prototype.destroy = function() {
return Cesium.destroyObject(this);
var scene = viewer.scene;
var primitives = scene.primitives;
primitives.add(new Cesium.QuadtreePrimitive({
tileProvider : new DemoTileProvider()
How should I do to make it work in 1.32 and draw less rectangle by modifying the geometricError?
Thank you.
Chris
