I’ve notice that in the current version of Cesium (1.14) there was a lot of changes regarding the QuadtreePrimitive, respect the previous versions…
I now that QuadtreePrimitive is a low-level API that is not documented thought the fact that is considered as “private” API but, do someone from the Cesium staff explain what was done on that approach?
For example, this code does not work anymore
TileProvider.prototype.loadTile = function(context, frameState, tile) {
tile.data = {};
tile.data.boundingSphere3D = Cesium.BoundingSphere.fromRectangle3D(tile.rectangle);
tile.data.boundingSphere2D = Cesium.BoundingSphere.fromRectangle2D(tile.rectangle, frameState.mapProjection);
tile.center = Cesium.Rectangle.center(tile.rectangle);
tile.centerCartesian3 = Cesium.Cartesian3.fromRadians((tile.center.longitude),(tile.center.latitude), 0);
tile.code = tile.x + “-” + tile.y + “-” + tile.level;
tile.state = Cesium.QuadtreeTileLoadState.DONE;
tile.renderable = true;
return;
…seems that the contents that was in “tile.rectangle” now can be found under “tile[index].owner”
Thx
Umberto
